Eject for removeable media
whitecrane
Post by whitecrane »
I know I can go to Explorer Menu and get Eject from there, but can Eject be added to the regular right click menu of V? Alternatively, can the Explorer Menu be cascaded in the manner of Send To or Tools?
I have loved and depended on V for most of its existence. A really superb and unmatched piece of work. THANK YOU!!
Re: Eject for removeable media
I'll look into it.
Unfortunately, no.
As an alternative, you can add a Windows command line program (eg, search for EjectMedia) to the User Commands and then select the option from the UserCommands menu to Eject (and even assign the User Command to a keyboard shortcut).
