Searching including 4DOS descript.ion
GeorgeB
Postby GeorgeB » Sat Apr 11, 2015 4:54 pm
Hi Charles,
V vers. 14 SR5 (x64)
I did a quick search, but didn't see this. I thought at one time search results would included matches inside the 4DOS descript.ion files. If it did do this, I can't make it do it now. If it didn't ever do this, is there a way to implement it? (Hopefully soon?)
--George Davis
Re: Searching including 4DOS descript.ion
Postby FileViewer » Sat Apr 11, 2015 11:04 pm
There is nothing special about descript.ion - it is not ignored by the search. I did a quick test and had no problem finding matches in descript.ion.
Can you be a bit more specific on what you did?
Perhaps send me a screen-shot of the search dialog before you pressed "Search" and also send me descript.ion (send to v at fileviewer.com).
GeorgeB
Postby GeorgeB » Mon Apr 13, 2015 10:33 am
Reply with attachments on the way.
--George
Users browsing this forum: No registered users and 21 guests
