V slowing down Eclipse
ctammes
Postby ctammes » Mon Oct 11, 2010 11:11 pm
Hi,
I have a problem with V together with Eclipse. I use Eclipse (3.6) on files that are on a remote Windows system (no FTP, connected via 'net use'). When I modify my file in Eclipse and press 'Save', the file is saved immediately. This is the normal process.
But sometimes, when V is active, the process of saving takes more than half a minute to finish. When I, during the save, quit V, the save process finishes immediately. So it seems that V influences the connection to the remote PC.
With a file on a local PC, the process is fast, no matter if V is active or not.
The strange thing is that this does not always occur. But when it does, it is reproducable.
When I load another program instead of V, for instance Firefox, eating a lot of memory, the save is fast as usual.
I did a test with Procmon (process monitor) active and these are the results from the same action. The first column displays a timestamp.
This is without V:
"08:42:04,2594435","eclipse.exe","5892","CreateFile","M:\Aposys\V5031\Batch\Conversie.bat","SUCCESS","Desired Access: Generic Write, Read Attributes, Disposition: OverwriteIf, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, Write, AllocationSize: 0, OpenResult: Overwritten"
"08:42:04,2611633","eclipse.exe","5892","ReadFile","C:\WINDOWS\CSC\00000001","SUCCESS","Offset: 0, Length: 64"
And this is the same result with V active:
"08:43:00,0081015","eclipse.exe","5892","CreateFile","M:\Aposys\V5031\Batch\Conversie.bat","SUCCESS","Desired Access: Generic Write, Read Attributes, Disposition: OverwriteIf, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, Write, AllocationSize: 0, OpenResult: Overwritten"
"08:43:40,9555316","eclipse.exe","5892","ReadFile","C:\WINDOWS\CSC\00000001","SUCCESS","Offset: 0, Length: 64"
Any suggestions??
Chris Tammes.
Re: V slowing down Eclipse
Postby FileViewer » Tue Oct 12, 2010 5:11 pm
Hi Chris,
I haven't heard of this problem before! Are you logging a folder on the remote drive with V when the problem occurs?
Next time you can reproduce it, try the following:
    1. Exit V and restart it. Does the problem persist?
    2. Use Notepad to save the file on the remote drive. Is this slow too?
    3. Remove the Explorer pane from V (by pressing the small x in the top right corner). Exit V and restart it. Does this make a difference?
ctammes
Postby ctammes » Fri Oct 15, 2010 1:54 am
Hi Charles,
I closed the Explorer pane for the instances of V that use the remote PC and that seems to work. Any idea why this might work??
Chris
Postby FileViewer » Fri Oct 15, 2010 3:00 am
Yes - otherwise I wouldn't have got you to try it :D
I need to send you a diagnostic version of V to track down the problem. Give me a couple of days.
Users browsing this forum: No registered users and 41 guests
