Folder Expansion
dbrannick
Folder Expansion
Postby dbrannick » Wed Mar 30, 2011 6:46 pm
There is a way to collapse open folders but is there a way to expand the folders automatically or by selecting an option? I have some directories that have many files within many subfolders. I'd like to open the main directory and have all the sub-directories expanded. Is this possible? thx
Re: Folder Expansion
Postby FileViewer » Wed Mar 30, 2011 8:41 pm
Is there a way to expand the folders automatically or by selecting an option?
No, there is no way of doing this at present. I will look at including this in the next version.
Do you just want the first level of the sub-directories expanded or do you also want any sub-directories of the sub-directories (and so on) expanded as well?
dbrannick
Postby dbrannick » Fri Apr 01, 2011 4:43 am
I think an option would be great to offer single level or multi-level expansions. So if I right clicked a directory, I might have an option to do a single level or multi-level expansion. I think this would be a great feature to offer.
thanks.
Users browsing this forum: Google [Bot] and 1 guest
