Version 12 - Preview 2 (GridLines Export to CSV)
Postby FileViewer » Sat Jul 03, 2010 8:51 pm
The second preview of V12 can now be downloaded from
Alternatively, you can select Check For Updates from V'sHelp menu.
The second preview allows files being viewed with GridLines to be exported as CSV files (Comma Separated Values). To do this, select Export to CSV from the GridLines menu. Note that the file must be being viewed with a GridLine for this option to be available.
For users familiar with CSV files, the options in the Export to CSV dialog should be self-explanatory. If you have any questions or problems, please submit them to this forum.
