Cannot Create Compress Folder
dbrannick
Postby dbrannick » Mon Jun 30, 2014 4:21 am
Went to folder, right clicked, selected send to compressed folder, got this message
Compressed (zipped) Folders
Windows cannot create the Compressed (zipped) folder here.
Do you want it to be placed on the desktop instead
Yes/No
What does this mean? I used to be able to do this.
V14 sr2 x64
Thanks.
Re: Cannot Create Compress Folder
Postby FileViewer » Mon Jun 30, 2014 6:54 pm
My guess is that you do not have permission to create the zip file in that folder. Is it a Windows system folder?
Try using Windows Explorer to see if you get the same message.
You will either have to run V "As Administrator" or create the zip file in a different folder and then move it to the folder you want (you will receive a UAC popup when doing the move).
