prompt for password
fpefpe
prompt for password
Postby fpefpe » Fri Jan 24, 2014 10:01 am
Hello -- Is there an option or setting to have V prompt for a userid/password when traversing into a network share?
When I do this via "my network places" (xp) it will prompt me for a userid/password when I select a share that requires it
Thanks
fpe
Re: prompt for password
Postby FileViewer » Fri Jan 24, 2014 7:59 pm
No, unfortunately there isn't.
If you want to access such folders, you will have to first authorize yourself using Windows Explorer - you should then be able to access the share in V.
I will try do something about this in a future version.
fpefpe
Postby fpefpe » Sat Jan 25, 2014 8:43 pm
thanks for the reply ... as noted that is what I am doing ... once I entered the password, V works fine
Users browsing this forum: No registered users and 2 guests
