Version 14 - Release Candidate 1
Postby FileViewer » Sun Jan 20, 2013 7:31 pm
The first Release Candidate of of V14 is now available at:
If you are currently running one of the betas you can upgrade by selecting "Check for Updates" from the Help menu.
If you are using the new CSV functionality, I would recommend that you upgrade to the release candidate as it provides better CSV file recognition.
Further details on the CSV functionality can be found here:
If all goes well, V14 will be released in a few weeks.
If you find any problems with the release candidate, please report them as soon as possible. You can either send me an email or use this forum.
(I have disabled URL links in this forum, so you will have to copy the above URLs and paste them into your browser)
