Version 14 - Beta 2
Version 14 - Beta 2
Postby FileViewer » Wed Dec 26, 2012 7:23 pm
The second V14 beta can now be downloaded from:
If you are currently running the first beta, you can upgrade by selecting Check for Updates from the Help menu.
The second beta provides improved support for CSV files including a Force CSV option which can be used if V does not recognize a file as CSV. Further details can be found here:
The above link also contains details on how you can customize the column headers when viewing a CSV file.
(I have disabled URL links in this forum, so you will have to copy the above URLs and paste them into your browser)
