Just discovered a small anomaly:
Dual pane mode. Multiple tabs open, each tab showing a couple of subdirectories deep. All tabs don't show, have to use either the arrow nav buttons to navigate to each, or use Ctrl-1, etc, to navigate to each. Focus on the last tab. Close V. Re-open V. Only the last tab is showing, it looks like there is only one tab open, although the "x" close button and left-right arrows are clues that there is more than one tab. It's just that with a quick glance it looks like there is only one tab in that pane.
I actually opened up V this morning with at least 12 tabs in the right pane, some of them duplicates.
If the tabs are short, i.e. don't overflow the full width of the file list pane, then this doesn't happen.
Windows XP SP3. Haven't tested this on my wife's Win7 Pro machine yet. Hopefully she'll let me use it soon .
--George
Pane Tabs Vers. 14 Beta 1
Re: Pane Tabs Vers. 14 Beta 1
Can you send a screen shot to v at fileviewer.com?
Also, right-click on one of the tab headings and select Global Tab Settings.
Do you have Display Full Folder Path enabled?
Do you have anything in the Maximum Tab Width?
On the way.
--George
Update: just discovered my email service provider has been having problems, I thought it was at my end, so it's possible I may have sent 3 or more copies of my email. Or maybe none. Let me know if you didn't get at least one, or if I'm now in your sp*m filter.
--George Again
--George
--George Again
Thanks for sending the screen shots.
I will fix the problem in the next beta.
Users browsing this forum: No registered users and 18 guests
