V The File Viewer Silent Switch
krnj34
Postby krnj34 » Thu Apr 28, 2011 7:23 am
Hi,
I need to package the software in SCCM for deployment. Is there a switch for silencing the executable?
Re: V The File Viewer Silent Switch
Postby FileViewer » Thu Apr 28, 2011 5:43 pm
There is no switch to silence the default executable that is downloaded (eg, v12.exe).
However, v12.exe is a self-extracting ZIP file which extracts all files to a temporary folder and then runs setup.exe (which does have a silent switch).
To do a silent install, you will need to manually extract all the files in v12.exe (you can do this in V by selecting v12.exe and then pressing Ctrl+Z).
You can then use the /auto switch on setup.exe to silently install V. You can list all the valid switches by running setup /?
Let me know if you have any further questions.
Users browsing this forum: No registered users and 2 guests
