file copy from a network drive to C or D and vice versa
djbeam
Postby djbeam » Sun Jun 26, 2016 9:17 am
I understand that V only deals with files that are listed under Explorer either as a lettered drive or identified under Network.
I have a BlackBerry PRIV Android system, and the the BB does show under the File category of Network but I cannot access or move files from or to it from the C or D drives.
What settings should be in place both for the PC and V to make this happen ..
Direction please ..
Re: file copy from a network drive to C or D and vice versa
Postby FileViewer » Sun Jun 26, 2016 4:17 pm
Unfortunately, there are no settings because this is not supported.
I will probably include support in a future version of V, but I can't see it happening any time soon.
djbeam
Postby djbeam » Mon Jun 27, 2016 3:12 pm
Then I am really confused, as I have read in the documentation of V, that Vsupports lettered directories and any directory identified under "computer" and "network".
Where did I go wrong?
Postby FileViewer » Tue Jun 28, 2016 9:55 pm
I have read in the documentation of V, that V supports lettered directories and any directory identified under "computer" and "network".
V only supports network drives (which contain a file system). The Blackberry must be configured as a device.
Network printers sometimes show up under Network but V cannot browse the contents.
The only way to view the Blackberry with V is if you could somehow assign a drive letter to it. Perhaps it came with some software that lets you do this.
