Somehow I messed up the layout of FileViewer, how do I remove all configuration or get to the point where it shows the 3 layouts at the first install?
Carmon
Layout messed up
Re: Layout messed up
You will need to uninstall V (from the Windows Control Panel) and then re-install it.
If you have accidentally removed the Explorer tree, you can display it by selecting Explorer Tree from the View menu.
If you have removed the dual pane mode, you can re-enable it by selecting Split from the View menu.
Users browsing this forum: No registered users and 20 guests
